errror message : call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x991
I have the following problem:
I have set up a CTI port with an extension 2912 which then set up call forward all to an international number, however every time when I dial this extension, it only ring for 2 seconds and then hang up.
I have run a debug and has error message
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
Nov  9 08:54:10.995 JST: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0022
        Bearer Capability i = 0x9090A2
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA193040000
                Preferred, Channel 4
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
        Calling Party Number i = 0x00A3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '62022912'
Nov  9 08:54:11.059 JST: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8022
        Channel ID i = 0xA993040000
                Exclusive, Channel 4
Nov  9 08:54:11.099 JST: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0x11 is 0x0 0x0, Calling num 62022912
Nov  9 08:54:11.107 JST: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0x11 is 0x0 0x0, Called num 010852800966276
Nov  9 08:54:11.111 JST: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x1082
                Standard = CCITT
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Calling Party Number i = 0x0081, '62022912'
        Called Party Number i = 0x80, '010852800966276'
WWW-VG1#
Nov  9 08:54:11.247 JST: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9082
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
Nov  9 08:54:14.071 JST: ISDN Se1/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8022
        Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
Nov  9 08:54:15.999 JST: ISDN Se1/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x9082
        Progress Ind i = 0x8482 - Destination address is non-ISDN
        Progress Ind i = 0x8488 - In-band info or appropriate now available
Nov  9 08:54:16.095 JST: ISDN Se1/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x9082
Nov  9 08:54:16.107 JST: ISDN Se1/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x1082
Nov  9 08:54:16.239 JST: ISDN Se1/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x8022
Nov  9 08:54:16.475 JST: ISDN Se1/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0022
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#
Nov  9 08:54:21.776 JST: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x0022
        Cause i = 0x8490 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov  9 08:54:21.784 JST: ISDN Se1/0:23 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x991
Nov  9 08:54:21.820 JST: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x8022
Nov  9 08:54:21.860 JST: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0022
Nov  9 08:54:21.880 JST: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x1082
        Cause i = 0x8090 - Normal call clearing
WWW-VG1#
Nov  9 08:54:22.048 JST: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x9082
Nov  9 08:54:22.056 JST: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x1082
WWW-VG1#
WWW-VG1#
WWW-VG1#
WWW-VG1#undebug all
All possible debugging has been turned off
WWW-VG1#term no mon
WWW-VG1#
It may be due to the way the telco switch expects progress messages. Try adding the global command “voice call disc-pi-off”.
HTH,
Jesse
Thanks Jesse,I experienced
Thanks Jesse,
I experienced this very issue on a voice gateway we have in Accra, Ghana where if the outside calling party hung up the call the internal Cisco phone user would just receive a fast busy tone. I was receiving the "call_disc: PI received in disconnect; Postpone sending RELEASE" message in my ISDN Q.931 debugs. I added the suggested command "VOICE CALL DISC-PI-OFF", and it fixed my issue. The internal Cisco phone user no longer has to hang up the call themself. Two thumbs-up!
3977
