Estimating phone firmware upgrade duration
I need to upgrade a large number of cisco phones spread across multiple sites with varying bandwidth.
Is there any way I can estimate the time it will take to upgrade a specific site based on the number of phones, firmware image size, WAN bandwidth etc?
1 ACCEPTED SOLUTION
Re: Estimating phone firmware upgrade duration
Table 3-4 TFTP File Transfer Times for SCCP Devices
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/netstruc.html#wp1050963
If not your version just open the SRND from your version in same chapter for specifics.
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
why don't you enable peer firmware sharing first then perform your upgrades, it will save lots of time when upgrading firmware.
There are dependencies but if your lucky you'll using a similar phone type and thus pulling the image once over the WAN.
229
