Community Member
eTokens for Cisco UCM
So I understand that an eToken is requried in order to do any security in Cisco UCM (phones, voice ports).  Is there any alternatives without using eTokens?
If the eTokens are required do we HAVE to use the Cisco USB eTokens (i believe the part number is KEY-CCM-ADMIN-K9)?  Can we use eTokens by Aladdin (which is a lot cheaper)?
And last why do we need 2 eTokens (from what I read in a document)?  Can we use only one eToken?
Any help to confirm these things would be great!
Thanks in advanced!
-rya
1 ACCEPTED SOLUTION
Re: eTokens for Cisco UCM
Yes, AFAIK that's the correct part number for the USB tokens
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Before you configure the Cisco CTL Client, verify  that you activated the Cisco CTL Provider service and the Cisco  Certificate Authority Proxy Function service in Cisco Unified  Serviceability. Obtain at least two security tokens; the Cisco  certificate authority issues these security tokens. The security tokens  must come from Cisco. You will insert the tokens one at a time into the  USB port on the server/workstation. If you do not have a USB port on the  server, you may use a USB PCI card.
Cisco Unified Communications Manager Security  Guide, Release 8.0(2)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/security/8_0_2/secugd/secuauth.html
From "security by default" chapter on above link:
Note Secure Signaling and Media will still  require running the CTL Client and using the hardware eTokens.
java
java
Community Member
Thanks Java!
So is this the part number for the Cisco eTokens required: KEY-CCM-ADMIN-K9
Thank you!
-rya
java
java
499
