Event Log error Cisco CTIManager on CCM 4.2(1)
Hi to all,
Today i check the logs of the CCM Publisher 4.2(1) and i received every minute this error ->
Source : Cisco CTIMANAGER
Type: error Category: none
Event id:3
Explanation: the JTAPI/TAPI application version is not compatible with this version of CCM.the message has been rejected.
Need some help
Re: Event Log error Cisco CTIManager on CCM 4.2(1)
do you have the JTAPI installed on the server?
Have you upgraded or integrated any new JTAPI apps to that server that are not using the right JTAPI version?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Hi javalenc,
JTAPI is installed on the server,
This is the publisher and just have the databases, we have another CCM Subscribers.
i read this document already but dont have the client ip on the log http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008084de1a.shtml
mmm, i had one of those back at TAC. i had to review the whole set of CTIManager detailed traces to find out the IP and hostname of the device generating the error
your best chance is to do the same if you get something like this:
Description:
Error: kCtiIncompatibleProtocolVersion - Incompatible protocol version.
UNKNOWN_PARAMTYPE:Message Version: 327680
UNKNOWN_PARAMTYPE:Minimum Version: 393216
UNKNOWN_PARAMTYPE:Current Version: 393219
App ID: Cisco CTIManager
Cluster ID: javalenc-Cluster
Node ID: 10.220.110.10
javalenc
java
Hi again javalenc
I'm grateful for your support
My Description:
UNKNOWN_PARAMTYPE:Message Version: 393218
UNKNOWN_PARAMTYPE:Current Version: 393217
How can i review the cti?
thanks again
i really cannot explain how to review traces as it's a long and complicated thing. it took me several months to learn how to read them, if you need help reviewing them and fixing the issue i'd recommend to open a TAC case, provide them that error along with the CTIManager detailed traces and they should be able to find the host that's generating the error message
javalenc
java
I will do it,
thanks a lot
182
