Community Member
Event viewer errors
I have these errors every 15 minutes or so, can someone tell me what's wrong? I don't have any other problems reported that could be related to media resources. Any hint would be appreciated.
Event Type: Error
Event Source: Cisco IP Voice Media Streaming App
Event Category: None
Event ID: 3
Date: 9/9/2008
Time: 8:28:24 AM
User: N/A
Computer: PUBLISHER
Description:
Error: kDeviceDriverError - IP voice media streaming device driver error.
Error: Error: ipvms mixer encountering time delays (2094)
App ID: Cisco IP Voice Media Streaming App
Cluster ID: PUBLISHER-Cluster
Node ID: x.x.x.x
Explanation: The IP voice media streaming device driver returned an error.
Recommended Action: .
Thanks.
1 REPLY
Re: Event viewer errors
first of all try to restart the IPVMS service on PUB
also check the config of any HW resources
if still no avail i'd recommend to open a TAC so they can investigate this since it's not a common error the one you're getting
java
if this helps, please rate
java
www.cisco.com/go/pdi
201
