02-01-2012 02:13 PM - edited 03-16-2019 09:21 AM
Hey guys,
So i am having an issue at one of my sites. There is a analog line plugged into an FXO port 0/0/0 the phone number is 2505551111 WHenever anyone calls this number it shows on the call display that 911 is calling. This number is connected to the voice port below, which then plars the number you see there (2505551234)
voice-port 0/0/0
connection plar opx 2505551234
Once here it goes to the below dial-peer which sends it to our UCM (172.xx.0.111) which then rings their mainline (2505551111) which is the second line on everyone's phone.
dial-peer voice 30 voip
tone ringback alert-no-PI
description for inbound 911 to mainline
preference 1
destination-pattern 2505551234
session target ipv4:172.xx.0.111
dtmf-relay h245-alphanumeric
no vad
for some reason, whenever I call 2505551111 from my cell phone (or anyone's phone) it shows up as 911 on the caller ID.
Does anyone know where I should be looking? I can't see anything on my pub that would cause this and there is nothing on the router either.
here is the dial peer debug.
Feb 1 13:38:29.920 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x49536A2C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_PORT;
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=911
Feb 1 13:38:29.920 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6169
Feb 1 13:38:29.936 PST: //-1/EA9125C78036/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2505551111, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=2505551111
Feb 1 13:38:29.936 PST: //-1/EA9125C78036/DPM/dpMatchCore:
Dial String=2505551111, Expanded String=2505551111, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 1 13:38:29.936 PST: //-1/EA9125C78036/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=30 Is Matched
Result=Success(0) after DP_MATCH_DEST
Feb 1 13:38:29.936 PST: //-1/EA9125C78036/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=30
Feb 1 13:38:29.940 PST: //-1/EA9125C78036/DPM/MatchNextPeer:
Feb 1 13:38:29.940 PST: //-1/EA9125C78036/DPM/dpMatchPeersCore:
Feb 1 13:38:29.940 PST: //-1/EA9125C78036/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=30
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=2505551111, Called Number=2505551111, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=2505551111, Expanded String=2505551111, Calling Number=2505551111T
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=30
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=2505551111, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Match Rule=DP_MATCH_ANSWER; Calling Number=2505551111
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
Dial String=, Expanded String=, Calling Number=2505551111T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5615
Match Rule=DP_MATCH_ORIGINATE; Calling Number=2505551111
Result=Success(0); Incoming Dial-peer=30 Is Matched
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=30
Feb 1 13:38:29.940 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6215
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5615
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6215
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 1 13:38:29.944 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=30
Feb 1 13:38:29.948 PST: //-1/EA9125C78036/DPM/dpMatchPeersCore:
Feb 1 13:38:29.948 PST: //-1/EA9125C78036/DPM/dpMatchCore:
SMY-RV-01#Dial String=2505551111, Expanded String=2505551111, Calling Number=
Feb 1 13:38:29.948 PST: //-1/EA9125C78036/DPM/MatchNextPeer:
Feb 1 13:38:29.948 PST: //-1/EA9125C78036/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=30
Feb 1 13:38:30.024 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=911, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=911
Feb 1 13:38:30.024 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=911, Expanded String=911, Calling Number=
Feb 1 13:38:30.024 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=911 Is Matched
Result=Success(0); Outgoing Dial-peer=10 Is Matched
Feb 1 13:38:30.024 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=911
2: Dial-peer Tag=10
Feb 1 13:38:30.028 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 1 13:38:30.028 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 1 13:38:30.028 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=30
SMY-RV-01#
Feb 1 13:38:33.204 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 1 13:38:33.204 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Feb 1 13:38:33.204 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 1 13:38:33.208 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 1 13:38:33.208 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
2: Dial-peer Tag=10
Feb 1 13:38:33.208 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Feb 1 13:38:33.208 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=SUCCESS(0)
1: Dial-peer Tag=30
SMY-RV-01#
Feb 1 13:38:41.712 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 1 13:38:41.712 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Feb 1 13:38:41.712 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
Feb 1 13:38:41.712 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5615
Feb 1 13:38:41.712 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 1 13:38:41.716 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6215
Feb 1 13:38:41.724 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=911, Called Number=, Voice-Interface=0x0,
Match Rule=DP_MATCH_ANSWER; Calling Number=911
Feb 1 13:38:41.724 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Feb 1 13:38:41.724 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=911T
Result=-1
Feb 1 13:38:41.724 PST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5615
Match Rule=DP_MATCH_ORIGINATE; Calling Number=911
Feb 1 13:38:41.724 PST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=911 Is Matched
SMY-RV-01#Result=Success(0); Incoming Dial-peer=10 Is Matched
Result=NO_MATCH(-1) After All Match Rules Attempt
Feb 1 13:38:41.724 PST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6215
02-01-2012 03:24 PM
Can you post your full GW config?
Chris
02-01-2012 04:11 PM
Whenever calling number is not received on POTS leg, the inbound dial-peer's "Destination-pattern" is used as ANI.
You can create a dial-peer with just the port command and place it above the 911 dial-peer in config and that shoud take care of the issue.
Udit
