Community Member
EVM-HD-8FXS/DID activation
I want to activate the 8FXS on my Gateway ( 2921 ), can you help me with the proper step/command to be able to activate the port.
Cisco CISCO2921/K9 (revision 1.0) with 884736K/49152K bytes of memory.
Processor board ID xxxxxxxxxxx
3 Gigabit Ethernet interfaces
108 Serial interfaces
4 ISDN Basic Rate interfaces
1 terminal line
4 Channelized E1/PRI ports
24 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
SCCP is the easiest but only supports T38 NSE based, if you are fine with it then go with it.
SIP and H323 are the most robust and both support protocol based T38 and SG3 speeds with proper IOS version, however these are peer to peer protocols, which means you will need to configure the GW as either SIP trunk or H323 GW on CUCM and then build dial peers on the gateway, so this will not  let you build nice devices with DNs in CUCM like you do with SCCP and MGCP.  If any of the devices will need supplementary features such as hold, transfer, etc then SCCP is the only protocol that supports it.
HTH, please rate all useful posts!
CHris
What protocol are you planning on using to control these?
Are these to be integrated with CUCM, CME or something else?
Chris
Community Member
I will integrate with CUCM ( 8.6.2 ), I want to replace 11 ATA 187  module which I am using right now for the Fax machine.
Are you planning on using these as SCCP, MGCP, H323 or SIP?
What drives the answer is really if you need T38 protocol based support, SG3 support, any supplementary call features for analog phones.
Chris
Community Member
What is the best way ( protocol ) for basic config?
CHris
Community Member
I will use the SCCP protocol, do you know the steps to activate on the Gateway the ports?
Thanks a lot for help
Silver
To add to Chris's posts, you can simply type "sccp" while in conf t.  Then do a "do show sccp" and that should then show your sccp state.
Please rate helpful posts
Tony
Community Member
From the Gateway:
(config)#do show sccp
SCCP Admin State: DOWN
Gateway Local Interface: None
IP Precedence: 5
User Masked Codec list: None
Silver
my next question would be if your router has the following....if not, add the below
sccp local GigabitEthernet0/0
sccp ccm "CUCM Sub IP" identifier 1 version 7.0
sccp ccm "CUCM Pub IP" identifier 2 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
Then do a show sccp to see if its now in a UP state
Tony
Community Member
So do proper config with SCCP will be????
conf terminal
sccp
sccp ccm group 1
sccp ccm 10.0.0.0 priority 1
sccp ccm 10.x.x.x priority 2
sccp switchback timeout guard 180
sccp ccm "10.0.0.0"identifier 1 version 8.6
sccp ccm "10.x.x.0"identifier 2 version 8.6
sccp ip precedence 5
sccp
en
show inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: xxxxx, Hw        Revision: 1.0"
PID: CISCO2921/K9      , VID: V08 , SN: xxxxxxxxxxx
NAME: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot        0", DESCR: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-4MFT-T1/E1  , VID: V01 ,
NAME: "4-port Wan Interface Card BRI S/T on Slot 0 SubSlot 3", DESCR: "4-port Wa        n Interface Card BRI S/T"
PID: HWIC-4B-S/T       , VID: V02 ,
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP        DIMM with 128 Channels"
PID: PVDM3-128         , VID: V01 ,
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Ada        pter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01,
NAME: "High Density Voice Module - 8FXS/DID on Slot 1", DESCR: "High Density Voi        ce Module - 8FXS/DID"
PID: EVM-HD-8FXS/DID   , VID: V05 ,
NAME: "3rd generation eight port FXS DID voice interface daughtercard on Slot 1        SubSlot 0", DESCR: "3rd generation eight port FXS DID voice interface daughterca        rd"
PID: EM3-HDA-8FXS/DID  , VID: V03 ,
NAME: "3rd generation eight port FXS DID voice interface daughtercard on Slot 1        SubSlot 1", DESCR: "3rd generation eight port FXS DID voice interface daughterca        rd"
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V03 ,
Silver
More like this...
conf terminal
sccp
exit
conf terminal
sccp ccm group 1
exit
Tony
Community Member
conf terminal
(config)#sccp ccm 10.0.0.0 identifier 1 8.6 I receive ( % Invalid input detected at '^' marker. )
The CCM version is not specified. Retype and specify the version parameter. If not applicable or if to use the default, explicitly specify version 3.1.
Hall of Fame Super Gold
Gabriel Ulici wrote:
conf terminal
Just do what CLI is telling you to do.
Community Member
In this case what sould I have to do????
1101
