EVM-HD-8FXS/DID install issue
We have a customer with 2 EVM-HD-8FXS/DID modules.
When they install either of them into a 2851 router, the card is not recognised.
Is there any config required to see the card (like with an E1 card), or is it dependent on the slot on the router.
thanks
Colin
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: EVM-HD-8FXS/DID install issue
My understanding is that ISR G2 requires EM3-HDA-8FXS/DID, while the 28xx / 38xx requires EM-HDA-8FXS/DID.
Hall of Fame Super Red
Hi Colin,
If the module is not recognised the likely culprit
is a lack of DSP resources    via PVDM2s.
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
He has an EVM-HD-8FXS/DID card with 2 x EM3-HDA-8FXS/DID expansion modules.
If he uses the older type of module (EM-HDA-8FXS) then it is OK.
Would the EM3-HDA-8FXS/DID modules require the use of a DSP3 ?
Are the EM-HDA-8FXS/DID modules still available
Yes they are.
648
