02-23-2012 01:01 PM - edited 03-16-2019 09:45 AM
Hi experts
Is there any way to export a list of translation patterns from CUCM 5x.
Solved! Go to Solution.
02-24-2012 12:10 PM
Good stuff...
Please remember to rate replies and mark 'answered' if appropriate!
02-23-2012 02:08 PM
sorry, but import/export feature was not added until CUCM 6.0.
Chris
02-24-2012 12:57 AM
Unless you are feeling adventurous:
admin:run sql select dnorpattern,calledpartytransformationmask from numplan where tkpatternusage = 3
dnorpattern calledpartytransformationmask
888 304500
0 223322
*6333 9812006
9999
222254
22200[5-8] 0
Take a look at the DB definition guide to wee what other fields you might like. You can log this to text then load it with Excel or whatever.
Aaron
02-24-2012 09:45 AM
Thanks Aaron
The SQL queries work wonderfully
02-24-2012 12:10 PM
Good stuff...
