Export Unity users to another server same version
I have a project to export unity users to another unity server both are running the same version. is there a utility to do a export and import?
Re: Export Unity users to another server same version
Is this voicemail only or Unified messaging ? If Unified messaging, then you cannot import users when the users are already homed on one Unity server. (assuming both Unity servers are homed to same AD). You will need to use the tool called RemoveSubscriberProperties to remove the Unity server association in AD for each subscriber from Unity Server1, before importing those users in Unity Server2.
If both servers are voicemail only, then You can use the Subscriber Information Dump utility and select the required fields.
http://www.ciscounitytools.com/APP_subr_info_dump_3x.htm
well there unified both homed to different AD.
You can still use Subscriber info dump. From the dump file, create a CSV file for import (Firstname, lastname, dtmf_access_id). The file headers can be found in Unity Tools Depot help page for Bulk Import Exchange tool.Once the file is created, you will need to go to the target Unity server, use the Bulk Import Exchange tool (assuming all the users do exist in the target domain) to import the users.
Sankar.
PS: please remember to rate posts!
Can i export them... the import then to another unity server different mail storage
111
