Exported files from CUCM
files exported from CallManager (like configuration or extention list) are in .tar format and there is no option to download the file in local computer. Any clue???
Everyone's tags (1)
I am not sure if you are referring to the Backup tar file or the export files through BAT (Bulk Administrator Tool).
I will provide you the links for both these feature export operations.
For Backing up CUCM through DRS, use the below link.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/drs/8_6_1/drsag861.html
And for exporting different files through BAT,
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/bat/8_6_1/bat-861-cm.html
(please refer the export option in index in the above link, which will lead you to different references for exporting different files from CUCM).
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answer !!
If you mean stuff you export via BAT there's a download/upload option under the BAT menu for such things
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
428
