Exporting / Importing Attendant Console Speed Dials
I was searching on how to do this and didn't see a complete answer so here is what worked for me:
First get the Attendants raw XML file.  Tac case collection located here http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K25073648
shows how to do that.
-  Delete the text at the beginning of the file till you get to the fist <SpeedDialGroup name=
-  You then need to delete the bottom text of the file staring from <MainframeWindowPosition>  (that was where my Speel Dial XML data ended anyway)
-  Add a <SpeedDialUsers> to the very first line and a </SpeedDialUsers> end of the last line.
Now its easy to do a Find / Replace to change the XML tags for import it into UCM 7
Find
Replace
<G n=
</SpeedDialGroup></G>
<SpeedDialEntry><E>
<SpeedDialEntry></E>
<Name><N>
</Name></N>
<TelephoneNumber><T>
</TelephoneNumber></T>
<Notes><O>
</Notes></O>
Save the changed file,  and in the Attendant Console File --> Import Speed dials
Volia!!
566
