exporting Manufacturing Root Certificate and Manufacturing CA Certificate 7925G
according to the instructions there should be export link from phone web interface under certificate, but I don't see it.7925g.jpg
anybody have an idea how to export certificate from the phone?  trying to use EAP-TLS for mutual authentication using ACS 4.2.
thanks in advance
Yong
1 REPLY
Re: exporting Manufacturing Root Certificate and Manufacturing C
Check out the document I wrote for how to export those certificates from phones for use with a RADIUS server for 802.1x: https://supportforums.cisco.com/docs/DOC-25798.  I'm not sure if this procedure works for 7925 since I've never tried it but I would assume it would work.
Also the manufacturing root CA can be downloaded from the OS Administration page of CUCM.
875
