Community Member
Exporting the translation patterns and route patterns from CCM
We are still using CCM v4. ;-) Is there a way to export the list of translation patterns and route patterns, including its configuration details?
Thanks!
1 ACCEPTED SOLUTION
Community Member
Re: Exporting the translation patterns and route patterns from C
Go to Route Plan---->Route plan report
Click on find button with out any thing in the box (this will give you all route patterns etc) On the top right of the page you should see "view in file" where you can save it in a csv/excel file.
Neeraj
Community Member
Neeraj
Silver
Next step: import a route plan.
Callmanager 8 or 9 maybe version 10?
Community Member
thanks a lot for your help! and thanks to those who also replied. Its just now, we are still using version 4, so no option to export. Only thing i can do is to use 'View in file' and save it to excel.
1459
