Expressway Jabber MRA no audio & disconnect
I am facing issue when using Jabber through MRA using Expressway "C" & "E". I hear no audio on anyside whether using Jabber Windows or iPhone and the call disconnects after about 40 seconds. But internally they're working fine.
My deployment is single NIC and I am using the following:
CUCM : 10.5
IM&P : 10.5
Expressway C & E : X8.2
Jabber iPhone : 9.6.3
Jabber Windows : 9.7.4
Also, attached detail of the call.
Thank you.
 I gathered you are using
I gathered you are using Router on stick deployment for Expressway E, if yes;
Please ensure in ExpressWay E, System>IP
- Use dual network interfaces is set to NO
- ipv4 static NAT mode is ON and address has been set to public IP
Best is to enable logs to level 4
Please ensure and check logs at Expc and ExpE and you need to look for, if Expressway C is communicating with Public IP address of Exp E and if not then it could be one of the reason.
Also I am assuming, Unified communication status is all active and you can see no of SIP Audio calls there.
Taha
What was your resolution here
What was your resolution here?
1184
