Expressway Question
Hello Guys,
Where can I get Expressway which was released with CUCM 10 ? Is this the same as VCS Expressway ? I see it on the NFR page for 10 but I cant find it on the downloads..
VR
1 ACCEPTED SOLUTION
The install media on 8.1 is
The install media on 8.1 is the same for for VCS-C, VCS-E, EXP-C and EXP-E, depending on what licenses you install, it will be one or the other.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Thanks.. I have this one
Thanks.. I have this one "s42700x8_1_0.ova" ?? Can I get demo license ?
Also, does this work for CUCM 9.1.2 ? Is there any document on how to deploy this ? We basically want Jabber working without vpn.
Thanks again
VR
No idea on how to get demo
No idea on how to get demo licenses, reach your AM/SE for that.
AFAIK, collaboration edge, which is what you're asking about, requires 10.X to work
Expressway docs are online
http://www.cisco.com/c/en/us/support/unified-communications/expressway-series/tsd-products-support-series-home.html
java
Thanks a lot. Works with 9.1
Thanks a lot. Works with 9.1.2 actually.
95
