09-22-2008 08:04 AM - edited 03-15-2019 01:27 PM
Does ext mobility work with SRST? Does anyone have a document on this?
Solved! Go to Solution.
09-22-2008 01:18 PM
09-22-2008 08:25 AM
Hi Daniel,
Q. Do Cisco Unified SRST support Extension Mobility?
A. Cisco Unified SRST routers do not support Extension Mobility. IP phones rely on the support from Cisco Unified Communications Manager for Extension Mobility support. When in SRST mode, IP phones fall back to the SRST router with whatever profile it contains (extension number, etc.).
Hope this helps!
Rob
09-22-2008 08:59 AM
Thank you Rob for the quick reply. Does that mean when in SRST mode the end user is logged off of their profile and they use whatever is assigned to the phone before EM?
09-22-2008 01:18 PM
Hi Daniel,
Bingo! You are most correct my friend.
Cheers!
Rob
