EXT Mobility & SRST
Does ext mobility work with SRST? Does anyone have a document on this?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: EXT Mobility & SRST
Hi Daniel,
Bingo! You are most correct my friend.
Cheers!
Rob
Hi Daniel,
Q. Do Cisco Unified SRST support Extension Mobility?
A. Cisco Unified SRST routers do not support Extension Mobility. IP phones rely on the support from Cisco Unified Communications Manager for Extension Mobility support. When in SRST mode, IP phones fall back to the SRST router with whatever profile it contains (extension number, etc.).
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps2169/prod_qas0900aecd8028d113.html
Hope this helps!
Rob
Thank you Rob for the quick reply. Does that mean when in SRST mode the end user is logged off of their profile and they use whatever is assigned to the phone before EM?
Hi Daniel,
Cheers!
Rob
164
