Ext Mobility
Does anyone know if CM 4.2.3 has the ability to run a ext mobility report based on when a user logged On/Off?
1 ACCEPTED SOLUTION
Re: Ext Mobility
sorry, not possible with a reports. you would need to look directly into the DB for the logged in checkbox
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Re: Ext Mobility
java
java
113
