Extend POTS line via FXS/FXO cards?
We have a remote site with IP connectivity.  At a more-local site we have a POTS line for Fax, which we would like to extend to the remote site.  I've searched for config examples but keep coming up empty, which leads me to believe this isn't possible...
POTS ------| FXO  | WAN  |          | WAN  | FXS  |------ FAX
LINE       | PORT | PORT |----------| PORT | PORT |       MACHINE
                           MORE LOCAL               REMOTE
                                 ROUTER                  ROUTER
Unfortunatly we are not a Call Manager shop, but we were gifted a couple of 2600's with FXS and FXO cards during a building acqusition, so we have that going for us.
Everyone's tags (5)
Re: Extend POTS line via FXS/FXO cards?
I have done this before with no issue's, maybe my use was little bit different but same concept. My call flow was as follow:
PSTN ----- FXO----VGW 1--------------- VOIP ------------VG2 --------FXS-------PBX
where is you problem? what configuration you have done?
Thanks for the reply.
I haven't done any config, I was looking for some examples first...but have not found any.
The hardware I have available are two 2610XM routers, one with an FXS card, one with an FXO card.
Also, this is PBX-free, simply a POTS line extension.  I know there are other devices I could purchase to complete this task, but though I'd try to recycle some gifted hardware.
I think i had a document which contained example.
Also i can share with you a sample config if you want.
Best regards,
Nizar
That would be great!
Sorry for late reply.
You can check "Configure the Cisco 2651 Router" section in the below link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/241831al.pdf
This is one side FXO/FXS only, but if you have both sides or many sides its same concept.
you will use POTS dial-peer to go out through FXO, and you will use VOIP dial-peer through cisco gateways.
Let me know if that will help you.
Best regards,
Nizar
hey thanks a lot!  I am out of town the next few days but will get this set up as soon as possible!
2075
