Bronze
Extended the greeting time!!
Hi all,
One of my users want to create a greeting (for instance standard greeting for CallHandler or Subscriber), but it only allow 1 min and 30 sec.
Is there anyway to extend the length of time?? I look up the Unity Tools, but can't find any.
Ken
Hall of Fame Super Red
Re: Extended the greeting time!!
Hi Ken,
This can be changed :) My understanding is that the Greeting Length for a Call Handler is determined by the COS of the person recording the Greeting. Have a look;
Class of Service Greetings Settings
The class of service greetings setting specifies the maximum length of greetings.
Subscribers > Class of Service > Greetings Page
Field Considerations
Maximum Greeting Length in Seconds
Select the recording length allowed to subscribers assigned to this COS for recording greetings.
The range is 1 to 999 seconds; the default is 90 seconds.
If enabled, a warning tone will sound before the maximum greeting length is reached.
Hope this helps!
Rob
Bronze
Hey Rob,
Happy Holidays to You.
I changed the setting at COS, and assign to a subscriber. However, it still goes up to 1 min and 30 sec.
Do I need to reset the unity??
Ken
Hi Ken,
Unity should not need to be reset here. I have never seen this not work ?? Is the Subscriber the owner of this Call Handler? Can this subscriber record a personal greeting longer than 90 seconds? It almost sounds as if this change to the COS didn't save properly.
Let us know,
Rob
Bronze
The COS that I just created is only for subscriber use. Not to CallHandler.
Ken
Bronze
Rob,
I know the reason now. Since I RTP into Unity and record the greeting by clicking record red button at the subscriber, I need to assign administrator right to the subscriber.
If user uses their phone to set up the greeting, then I don't need assign administrator right to it.
Ken
Hi Ken,
Nice troubleshooting here! +5 points for this kind follow-up and in sharing your resolution to this issue.
Cheers!
Rob
139
