Community Member
Extending POTS line to a remote location
hello folks, i have a scenario which i need your assistance on.  The request is to extend the pots line via voip transport from the Main office to a remote location which is located two miles from the main office.  I have a couple of routers.  one with FXO (Main office) and FXS on the remote location.  can you guys send me a link to a configuration guide.  Also, is it possible to get it setup using two VG204's or one VGW in the main office and VG204 to the remote location.
please advise.  thanks
PSTN ----- FXO----VGW 1--------------- VOIP ------------VG2 --------FXS-------Analog phone
first you can have one of the blow options
analog phone VG204/h323----VOIP-----VGW---FXO--PSTN
analog phone VGW/FXS----VOIP----VGW/FXO----PSTN
in the remote side you will need to have two dial peers  one for the analog port called pots and the other one for voip to send the call out to the voice gatway
example let say the analog phone number will 0123555 connected to fxo port 0/1/0
dia-peer voice 1 port
destination-pattren 0123555
port 0/1/0
to send calls to PSTN assuming PSTN calls start with 0
dial-peer voice 2 voip
destination-pattren 0T
session traget ipv4:x.x.x.x    where x.x.x.x the other end voice gateway IP address
at the head office you will need to have voip dial peer to send the calls to number 0123555 to the remote office gateway or VG
and ports dial peer for the FXO
assuming the FXO port number is 0/0/0
dial-peer voice 10 ports
destination-pattern 0T
port 0/0/0
forward digits all
dial-peer voice 20 voip
destination-pattern 0123555
session target ipv:y.y.y.y    ---where y.y.y.y is the IP of the remote office VG,GW
voice-port 0/0/0
connection plar opx 0123555    to send calls to this number
see the below example
hoe this help
if helpful Rate
Community Member
thanks, i will configure and let you know.  I really appreciate your help
you welconme
Community Member
Hi again,
i installed a 4FXS-DID into a cisco 2801 router running c2801-ipvoicek9-mz.151-4.M2.bin code.  i applied the command voice-card 0 and i could not get the card or could not see the card in the router.  show ver shows that the card is there.  what am i missing here?  please let me know.  thanks
Cisco 2801 (revision 5.0) with 358400K/34816K bytes of memory.
Processor board ID FTX0937Y03G
6 FastEthernet interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
250368K bytes of ATA CompactFlash (Read/Write)
you need a UC license in order to be able to configure voice related commands
check with show software license and see if its there or not
if its not you need to order one if you did not yet
hope this help
