Extension and ANI numbers
hi all,
i have 3 digit of extension,when i call to any number&check in debug of isdn q931,calling number is same as of my extension and called number is my desired number like
" Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0181, '356'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '39583729' "
My telco wants me to send my complete ANI number which is 16535356 not only 3digit 356..and i also wants to keep 3digit extension!! how can we do that my extension remain 3digit but whn i call outside it should go complete 8digit number to my telco.
1 solution is this that i change my extension from 3digits to 8digits,but its not at all good ..does any one have any other option??? I've 1 call manager 6.0 with 1 MGCP Gateway having 1 PRI ..
1 ACCEPTED SOLUTION
Re: Extension and ANI numbers
u can easily do this with translation rules or dialplan patterns
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
java
if this helps, please rate
java
www.cisco.com/go/pdi
pretty simple, configure the external phone number mask to add the digits and check "use external phone party" in the route pattern,
or configure the calling party number mask in the route pattern,
or configure the calling party number mask in the appropriate GW in the route group the route pattern uses
java
java
hi java !!
its not wokring man !! any other solution !!!
where u set the mask and how does it look?
java
java
Thanks man .. its working now !! i was configuring it on wrong place but now its working fine !!!
one more question regarding to that !!! now i have to do almost same in CCME ... actualy my outgoing calls are working fine but incoming is not working .. in debug isdn q931 iam getting complete number from telco like 97316556633 ok and my actual number configured on ip phone is 16556633 so i need to remove 973 from incoming number so that it can match to ip phone and can able to kal .. in call manager i have done it through translation pattern !! but how we will do in CCME !!!
will appreciate if you will reply quickly !!
Reject Calls
java
java
216
