Extension calls itself?
Our front desk extension is 8200.  Every once and a while, a call will come in from extension 8200.  You cannot pick it up, and the only way to end it is let it go to voice mail, then disconnect.  When it happens, the person at the front desk is not doing anything on the phone.  Has anyone seen this before?  It only happens on the one extension.
We are using Call Manager V 6.1.3.2000-1
Thank you.
DLW
Everyone's tags (1)
Red
Re: Extension calls itself?
Do you have CUPS (Cisco Unified Presence Server) in your environment?
Thanks!
Michael
http://htluo.blogspot.com
No
Do you have a TAPI/JTAPI application in your environment?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes, our paging system is java based.  Is that related?
Red
What Java said was: if a human being didn't dial the phone, it had to be a software (CTI/JTAPI).
To isolate the problem, you might have to disable that software for testing purpose.
Michael
Yes, now I understand.  It’s not a human problem, it’s not a loose wire somewhere, it’s not an overheating Flux Capacitor, it’s a software problem!  Now we’re getting somewhere!
204
