Extension mobility between CME and CUCM
We use CUCM on our main sites. We've started to deploy CME on field offices.
Is it possible to activate extension mobility between CUCM and CME ?
ie: being able to log on a CME managed phone with a CUCM account and from CME to CUCM ?
Jaime Valencia
No, you can only do that between CUCM clusters, if both support EMCC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks for your answer, I was hopping to have someone with a by-pass solution...
NH
