Extension mobility call routing issues on 7912 and 7940
We have a problem with Extension Mobility. When the user logs on the 7970 can make calls to translation pattern *0.[67]XXXXXXX on the partition "disable_calling" and calling search “TARIFADAS”. When the user logs on the 7912 or 7940 cannot make calls to this pattern .We have a translation pattern to hide the extension number from the user when calls to internal numbers. Within translation pattern, on the section "calling party transformations" on the fields "Calling Line ID Presentation" and "Calling Name Presentation*" is "restricted". On the Dna analysis output, the call flow is correct and the result is “Route this pattern”. I try too make a specific route *071956062 and work only on 7970.
Cisco Unified CM Administration
System version: 6.1.3.3190-1
SCENARIO:
Extension: 2198
Partition: "ramal"
CSS: "CSS_FL_FIELD_TPATTERN"
Called number: *071956062
Partitions: "disable_calling"
TRANSLATION PATTERN:
Route: *0.[67]XXXXXXX
Description: local calls to mobile
Partition: disable_calling
Css: Tarifadas
Calling party transformations: "Calling Line ID Presentation" and "Calling Name Presentation*" is "restricted".
Route: 2XXX
Description: internal calls
Css: Tarifadas
CSS TARIFADAS
Partitions: PRT_FL_LOCAL_CELULAR, RAMAL
ROUTE PATTERNS
Route: *0.[6-9]XXXXXXX
Partition: PRT_FL_LOCAL_CELULAR
Route group: Gateways h323
ROUTE PATTERNS
Route: *0.71956062
Partition: MOBILE
OBSERVATIONS:
To even putting the partition “mobile” inside the css “private” as being to first option, the call is not completed. Example:
Extension: 2000
Partition: "ramal"
CSS PRIVATE
Partitions: option 1 "mobile"
option 2 "disable_calling"
I appended one file that explain better.
Hall of Fame Super Silver
Re: Extension mobility call routing issues on 7912 and 7940
Hello Eduardo,
have you created a user device profile for each phone model?
the line with the calling rights in what position is in the phone button template?
Hope to help
Giuseppe
Silver
As the user when logging on the 7970 is allowed to make the call then the combination of the Users CSS and the 7970 CSS are correct but when they log on to the other phones it fails. The issue must be with the other handsest CSS - check what Partitions are in the other handset`s CSS
Sorry, but What would be a handset? You want to say hardphone?
Both hardphone (7970, 7912) have the same css.
I removed to translation pattern *xxx and functioned correctly! Problem solved. BUT because functioned in the 7970 or IpCommunicator? In the partition disable_calling I had the following translation patterns: *xxxx 2xxx 3xxx 6xxx
Interesting it is that the callmanager is not going to choose the priority, what would be very helpful.
189
