Community Member
Extension Mobility Change PIN
Whilst upgrading my 7961G-GE to the lastest firmware [9.0(2)SR1], I was reading through the release notes and noticed the following:
The Extension Mobility Change PIN feature allows users to change their PIN from their Cisco Unified IP Phone.
Users can change their PIN by:
Using the Change Credentials Cisco Unified IP Phone service subscribed on a phone
Using the ChangePIN softkey on the Extension Mobility (EM) logout screen
This feature is supported on the following phones:
Cisco Unified IP Phone 7975G
Cisco Unified IP Phone 7971G-GE
Cisco Unified IP Phone 7970G
Cisco Unified IP Phone 7965G
Cisco Unified IP Phone 7962G
Cisco Unified IP Phone 7961G-GE
Cisco Unified IP Phone 7945G
Cisco Unified IP Phone 7942G
Cisco Unified IP Phone 7941G-GE
Cisco Unified IP Phone 7931G
Cisco Unified IP Phone 7911G
Cisco Unified IP Phone 7906G
I've hunted around and not been able to find anything more about this feature or how to enable it? The document doesn't specify that it's a CUCM8x feature so is it available for CUCM 7x and, if so, how the heck do you enable it?
Cheers
Bronze
Re: Extension Mobility Change PIN
From the document that you've pasted in it looks like you have to create the service and subscribe the phone to it. I'm running CUCM 7.1.3 and it's not a service that I can configure.
I've also looked at the softkey templates and cannot see one for ChangePIN, so I assume that it is a 8.x feature.
Cheers,
Phil
Yes it is 8
thanks
Community Member
please can you share this
please can you share this file with me  the extensions mobility for 7911g cisco phone thanks in advance
Features and services guide
Features and services guide has all the steps for EM and EMCC, along with the change PIN service, all available on cisco.com, simply search the one for your CUCM version under the main CUCM documentation page.
java
if this helps, please rate
www.cisco.com/go/pdi
1853
