Extension Mobility Cross Cluster with Shared Lines
All,
User A at extension 1111 on Cluster A has a shared line with User B of  1111 on another phone in Cluster A.   We are running into a problem when User A logs into a phone on Cluster B.  Calls to 1111 are routing to the shared line back on Cluster A and 1111 logged in through Extension Mobility on Cluster B never rings.
Out of the box  is EMCC not smart enough to still ring both phones?
Thanks in advance!  All replies rated.
Blue
It is supported. See "EMCC Interactions" section in below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fsemcc.html
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
there are some bugs related to phone and shared line
check the below one
 CSCtj71980    8945 SCCP - EMCC Share line doesn't work
thanks,
Vipul Jindal
Thanks Ronak and Vipul.  TAC said we are hitting bug CSCtc37051.  No workaround or fix as of yet.
377
