Extension Mobility CUCM7.1
I am very new to Cisco.
Could you please let me how to enable Exteniosn Mobility on auto registration phones?
Nirmal
Bronze
Re: Extension Mobility CUCM7.1
HI Nirmal,
To enable extension mobility do the following:
  • Add a new service from Device Settings - Phone Services. Service URL has to be the following with the IP address of your Publisher replacing x.x.x.x http://x.x.x.x:8080/emapp/EMAppServlet?device=#DEVICENAME#
  • Start the Cisco Extension Mobility service in serviceability page
  • Subscribe the phone to Extension Mobility (EM) service
  • Add device profile for user
  • Subscribe device profile to EM service
  • Add a new End user and assign the device profile that you just created to the user
  • Add the user to the Standard CCM End Users & Standard EM Authntication Proxy Rights groups
Cheers,
Phil
Hi Phil,
Thanks for your quick reply.
Is there any possibility to enable Extension Mobility on device configuration (Extension mobility check box) while a new phone is getting auto configured during auto registration process (Auto registration enabled Call manager).
Nirmal
Bronze
Hi Nirmal,
Unfortunately I don't think there is, i've had a look at this through the default device profiles, but you do not have the option. To be honest you have to configure so much on the phone anyway that one more check box doesn't really concern me.
You may be able to if you use BAT to add your phones in, but I have never used BAT myself.
Phil
Hi Phil.
Thanks for your quick response..
Nirmal
536
