extension mobility does not appear on ip phone
Hi Guys ,
i have a strange case on  a remote site .
In fact , when i connect an ip phone to a switch (2960)  on site B , the Extension mobility does 'nt on appear  when i press the services key .
However wheni connect the same ip phone to another switch it appears .
Did any one face this problem ?
Tanks
Hall of Fame Super Silver
What do you see when you press Services when connected to the 2960?  Is it on the same VLAN as the other switch?
Perhaps it cannot resolve the DNS of the EM service?
I  would suggest looking through the phone console logs for clues, you can  access the log by browsing to the IP address of the phone.
HTH,
Chris
Blue
Also see if any kind of ACL is applied in the network path when you are connecting it to problametic switch.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
196
