Extension Mobility Error: [6]
dbenattou
hello,
i have done an upgrade from 4.2.1 sr1b to 4.2.3.when i try to select the extension mobility service the Error [6] is displayed and cannot be logged.
Please i need help.
Chad Stachowicz
Level 6
Level 6
Look into the install Guide... The link for the service changed between the versions! You just need to update the service URL!
Chad
Hi, here's all the relevant EM error codes. Like Chad suggested (5*), have a look at the service URL to make sure it's correct (make sure it's resolving to IP not DNS).
Otherwise, this sounds like a database issue or a profile problem (have you checked they are associated properly in CCMAdmin)?
Have a look at the link at the bottom of the page, it has some useful information that should help you..
Error Code & Description
[0]
Unknown Error
[1]
XML Validation Error: Because the request or query was incorrectly formed, it cannot be properly processed.
[2]
Authentication Error: An error occurred in the authentication process, and the validity of the appID and appPassword that were submitted cannot be confirmed.
[3]
Invalid Authentication: The appID and/or appPassword that were provided are incorrect.
[4]
Policy Validation Error: Some generic issue exists regarding determination whether the request is allowed.
[5]
Request Denied: The request has been denied (failed Policy Validation) for one or more reasons.
[6]
Database Error: The Extension Mobility service received an error while trying to communicate with the database.
[7]
AutoLogout Setup Error: The system could not communicate with the AutoLogout service.
[8]
Query Type Unknown: The system could not determine whether the query is Device-User or User-Devices.
[9]
DirUser Creation Error: Directory integration error occurred.
[10]
Proxy Authentication Not Allowed: the appID that is specified does not have rights to log in or log out other users.
[11]
Device Does Not Exist: The specified device for login or logout does not exist in the system.
[12]
Device Profile Does Not Exist: Either a profile was specified that does not exist or no Logout Device Profile was configured for the specified user.
[18]
Device Already Logged In: The system could not log in to the specified device because a user is already logged in.
[19]
Device Not Logged In: Could not log out of the specified device because no user is logged in.
[20]
Get Device Hoteling Flag Error: The system could not determine whether the device allows Cisco Extension Mobility (also called "hoteling").
[21]
Get Device Hoteling Status Error: The system could not determine whether these is a user currently is logged in.
[22]
Device Does Not Allow Extension Mobility: The device that is specified is not configured for Extension Mobility.
[23]
User Does Not Exist: The userID that was entered for login does not exist in the system.
[25]
User Already Logged In Elsewhere: The system denied the0 login because the specified user is already logged in to a different device.
Troubleshooting Extension Mobility in Cisco CallManager:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080093e72.shtml#error6
Please rate useful posts..
hello,
The problem is resolved.
i have just applied release 4.2.3sr4a, to overcome this issue.
Thanks.
