Extension Mobility getting "Login is unavailable(25)"
I'm getting this error when trying to login to a 2nd phone with a user profile that is already logged in.  This is a new install of CUCM 8.5.  Not sure if it is a Service/Enterprise Parameter setting.
Thanks in advance.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
What is the "Multiple Login Behavior" EM service parameter set to?
Chris
Chris
Thanks Chris.  Apparently I don't see to well.
The default behavior for EM is not to allow multiple logins with the same user, you can change that in the EM service parameters.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
6577
