Extension Mobility Hang
I have experienced a hang on the extension mobility service. I configured it correctly and can login and logout. I experience a hang on logging in and out more often than being successful. Is it possible that this concerns low memory resource of the CallManager? Can I just add additional 2GB memory on the 7825I CallManager Server to increase the memory and will this solve the issue? Thanks in Advance =)
  • IP Telephony
Silver
Re: Extension Mobility Hang
Yes, by increasing the memory it might solve your problem. It looks like you're running on the min. amount of memory required.
Thanks for the reply Iris.
Is it also possible that it is a known bug to Cisco CallManager 6.0?
We raised this to TAC and they said it is a known bug so we are also considering it. If it is a known bug, it should have been fixed before for we are already running the latest version.
170
