Extension Mobility issue with CME 8.6
I am facing one issue with CME 8.6, the IOS is: 15.1.4 M2. I have enabled EM on CME. I have configured logout-profile & user-profile & other parameters. If i press EM in the phone, it asks the username & password, i am able to login. The problem is: the fone says registering & then hangs.....I need to press exit button for 2-3 times, then i get my profile. Same thing is happening while logging out... I am using 7942 with firmware version: cmterm-7942_7962-sccp.9-1-1SR1.......Have any ever came across any such issue? Kindly suggest..
Below is the config for EM:
voice logout-profile 1
pin 1234
user partha password 123456
number 290 type feature-ring
speed-dial 1 000 label "Reception"
voice user-profile 1
pin 5555
user samjath password cisco
number 213 type feature-ring
telephony-service
sdspfarm units 4
conference hardware
no auto-reg-ephone
authentication credential secretname password
em keep-history
max-ephones 109
max-dn 200
ip source-address 10.111.220.31 port 2000 secondary 10.111.220.32
timeouts interdigit 2 url services http://10.111.220.33/voiceview/common/login.do
url authentication http://10.111.220.32/CCMCIP/authenticate.asp secretname password
load 7942 SCCP42.9-1-1SR1S.loads
time-format 24
voicemail 200
max-conferences 6 gain -6
call-park system application
moh music-on-hold.au multicast moh 239.1.1.1 port 2100
web admin system name webadmin password c1sc0@123
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Feb 08 2012 12:16:41 !
ephone 1
mac-address D4D7.4840.0F96
ephone-template 1
busy-trigger-per-button 1
type 7942
logout-profile 1
ephone-dn 100 dual-line
number 290
Hall of Fame Super Gold
Won't help much, but this is being discussed here.
https://supportforums.cisco.com/message/3560602
You can delete this and post in the other thread.
Re: Extension Mobility issue with CME 8.6
Any solution??
Rgds,
Partha
Green
This sounds very much like BUG ID CSCsx66104
Cisco claim this was fixed in various IOS versions 12.4
It would seem that this FIX has not been reflected through to to Version 15.xxx
I think you need to raise a TAC and explain the issue is similar to BUG ID CSCsx66104
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
WE had the same problem, for which there are 2 contributors:
Please ensure that your phone locale is set to English UK
also,
Please restart the Tomcat service.
I am using CME, where can I find the Tomcat service?
Rgds,
partha
restart service cisco tomcat from the router command line.
to verify
utils service list and look for tomact[started]
to verify
Please read posts before writing.
OP has CME, not CM.
Green
Can you please read what I posted further UP
This looks like bug ID
CSCsx66104 : CME EM login,logout behavior abnormal, requires exit key to press 3 time
Symptom:
user login to Extension Mobility EM on IP phone.
-enters username and password.
-hits submit softkey
-phone shows loggin in .. updating locale....
-phone display screen stays and gets stuck there and it does not shows new profile and DN on the phone, untill user press the exit softkey 3 times.
- same behaviour is noticed on EM logout. which again requires 3 times exit softkey to press.
Conditions:
CME recently upgraded from 4.2 to 7.0
login to Extension mobility on IP phone.
Workaround:
None
Further Problem Description:
Issue wasn't noticed in CME 4.3 . but after upgrade to 7 ,consistently shows on almost all types of phones causes annoying behaviour.
Raise a TAC and quote this information.
Alex
Which version of IOS & CME are you using now??
Rgds,
partha
Hi Imran,
It should be user locale or network locale?
Did you manage to find out how to restart the tomcat service in cme?
Please reset user locale to UK. Though both should be configured that way-assuming u are in the UK of course;)
Imran Ul Haq wrote:
As mentioned above already ?
there is no tomcat service in cme
I am in Dubai, UAE.
I am having this issue and I have noticed that I am getting an error finding locale . What I don't understand is why this would cause the issue? I had the issue early on but upgraded to 8.5.4 and the problem went away. After looking at the matrix, I notcied that with the IOS we were running, we should be at firmware version 9.1.1. So I upgraded it to the 9.1.1 and now the problem is back.
We are experiencing the same issue with CME. Were you able to find a fix for this issue?
MIchael
Yes. I downgraded the firmware to 8.X from 9.X…
Thank you acharyr123,
We did the same and it resolved the issue.
2770
