extension mobility issue
123anupcisco
hi,
when i hit the services button in cipc, i dont get the link to em service.
i have created a phone service - EMCIPC
the string - http://192.168.1.28:8080/emapp/EMAppServlet?device=#DEVICENAME#
cucm 7x - 192.168.1.28
i have changed the url parameters from cucm7(servername) to ip.
created default device profile
subscribed the serivces to device profile
enabled EM on the phone..
but i still dont see the EMCIPC when i hit services button.. even after restarting EM service/ Call Manager service / Tom cat service and the phones as well.. what is the problem?
Jaime Valencia
You only mention you subscribed the UDP, but did you also subscribed the IPC??
Also, have you created a specific UDP for your IPC?? you only mention the default device profile
I'd recommend you to re-visit the EM config guide and make sure you're not missing any step
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
yes i did, all the above.. but i am running this cucm on virtual machine..so i did not turn on all the services. only call manager, EM, TFTP, CTI .. any other services that needs to be turned on.. for EM .
