extension mobility logging possibilities.
Harry Niemuller
i am looking for a way to log the times users login and logout using extension mobility.
I cannot seem to find how to do this.
Is it possible to log login and logout times of extension mobility users?
Preferably to SQl, but plain text is fine too.
i am using CUCM 6.1.3.
thanks,
harry
Jaime Valencia
AFAIK such info would only be recorded in the EM traces
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
