Extension Mobility Logging
Morning all,
does anyone know of a way to find out how to retrieve EM events? i.e. to see when a user has logged in and out of his phone?
I know you can do this with traces set up, but its a bit painful having to go through all of the notepads in the programmes/cisco/trace/em directory.
thanks in anticipation.
1 REPLY
Re: Extension Mobility Logging
only with traces, there is no report or easy way to do this
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
123
