Extension Mobility Login Query
Im looking for a query to run on CallManager to find out the last time a user logged in using extension mobility.
CallManager version is 4.1(3)
Anyone tried this before?
Bronze
Re: Extension Mobility Login Query
The Login Services API is an XML over HTTP interface for applications wanting to effect extension mobility logins, etc. One of the functions in this API is a query function, whereby an application can determine which user has logged into a device, or which device's) a user is logged into.Perhaps this is what you are referring to?
that would work....
VIP Super Bronze
bwilmoth,
How can one get this API?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
212
