Silver
Extension Mobility Logout Option
I have E/Mobility working but on some occasions the logout option does not appear after logging in?
So after I press the services button on the phone - I see is this:
SERVICES
To set the speed dial and other services for you phone goto (192.168.x.x)
I have explicitly enabled logout service under the phone configuration sub/un-sub services?
I have found a way to do it. Goto device phone and press logout button. But this of course is not feasible solution. If I login to a phone then I should be able to logout - period.
tia
Ajaz
1 ACCEPTED SOLUTION
Silver
Re: Extension Mobility Logout Option
in the device profile you create for each EM user, you have to subscribe to the extension mobility service as you did per phone device.
this done you will will be able to logout after you have logged in.
by the way you can create two extension mobility services with names login and logout, repectively. with the same url but only names differ.
subscribe EM login per phone and and subscribe logout per device profile.
this will be meaningful for you IPT users.
hth
/majdi
Silver
hth
/majdi
Silver
thanks Majdi
Ajaz :-)
169
