Extension Mobility Logs
Leonardo Santana
Its possible to know how much time a user doesnt log in with the EM User in a device?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Mateusz Pagacz
Hello Leonardo,
run sql select enduser.userid, extensionmobilitydynamic.logintime from enduser inner join extensionmobilitydynamic on extensionmobilitydynamic.fkenduser_lastlogin=enduser.pkid
where logintime is in UNIX epoch.
robin
Hi Leonardo,
There is a solution for this. it is called ALM PRO+.
ALM PRO+ allows companies to view ExtensionMobility usage and is able to run detailed reports for usage and management purposes.
  • Centralised administration for all sites/locations using ALM PRO
  • License management and control
  • Advanced reporting on EM usage
  • Extended management reporting options
  • Calculating work space usage
  • Manage user and group profiles
  • Web-based administration
Drop me a PM for more information
