Extension Mobility - Multiple Profiles Possible..
Hi, working on a situation were a nurse needs one profile when working in one department (unique extension, ect) and another profile when working in a different department. Is this possible? If so, how many roaming profiles can a user have.
Also, if that is not feasible, any other ideas? Thanks for your help!!
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Sure, it is possible, simply create as many as you need and associate them all to the user. I don't think there is a hard number limitation.
HTH,
Chris
HTH,
Chris
Awesome, thank you. So, the user would have multiple pins to login with depending on where they were working that day?
No, the PIN is always the same, when you select EM service and have multiple EM profiles associated they will be presented with a menu to pick the one they want to login with.
HTH, please rate all useful posts!
Chris
Thank you Thank you!
My pleasure, please rate the post if you found the answer helpful.
Chris
198
