Extension Mobility Not Updating after Successful Login
Got a customer recently upgraded to CUCM 9X. When user logs in with EM profile, the phone shows login successful but the extension never gets updated or the phone never restarts to get the profile. Any ideas why?
1. is the phones on the latest firmware for cucm 9.x?
2. restart your extension mobility service and tftp service under servicability on the cucm.
Voice CCIE #37771
yes, latest firmware and EM and tftp restarted previously but no luck. opening a ticket to see if this is a bug...thanks.
VIP Purple
Hi ,
what is the exact CUCM version u are using?
what is the phone model on which you are facing the issue and firmware ?
regds,
aman
Looks like they have a DB replication issue between the CUCMs which might be causing this.
VIP Purple
u can check the same by running utils dbreplication runtimestate from CLI .
regds,
aman
Hi,How did you solve this
How did you solve this problem finally, because we just facing to the same issue.
Zsolt
The issue ended up being a DB
The issue ended up being a DB replication issue with the CUCMs. Although on the surface and in any of the replication status shows it good, TAC found out it wasn't in the backend and had to fix it.
255
