Extension Mobility on CME7.0
Hi all,
Now my customer wants to deploy the Extension Mobility in their office, the CME version is 7.0.
I know that CME7.0 can support EM with the logout-profile and user-profile. But when I was configuring the two profiles, I found that there are little commands under it, so I can't specify the preference which included in the Ephone-dn configuration, such as name and description.
So does it mean that when I login another ip phone using EM, the configurtion under the ephone-dn can't appear, just the number? Is that right?
Thanks very much
Kirin
1 ACCEPTED SOLUTION
Re: Extension Mobility on CME7.0
You are correct. Just indicate number under the EM profile, and it will pull information from the ephone-dn that you have configured.
Not sure if you have seen this are not..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html
I figured this might help to understand limitations.
Hi kelvin,
Thanks for your replay. I have read the documentation about the EM configuration before, it doesn't indicate the limitations definitely. I just seen there are less commands than in the ephone-dn configuration.
But someone told me that if I use the command "number" under the user-profile or logout-profile configuration, it will associate the ephone-dn information which has the same number. So when a user login on the phone, his personal information will appear on the phone. So it means there is no need to configure the personal info under the user-profile, just the same number as ephone-dn.
Is that right? Did anyone deploy the feature before?
Kirin
Hi Esther,
Thanks.
However I think cisco should indicate the information in the CME configuration guide.
143
