Extension Mobility PIN
miket
Level 5
Level 5
Dies anyone know if when we log onto a extension mobility device is the pin number sent in clear text? The same for the ccmuser page is the password in clear text.
I have security asking me and I suspect it is in clear text.
Jaime Valencia
AFAIK it's clear text as you mention, that is not a secured connection
javalenc
if this helps, please rate
java
Thanks I will rate ..... Can you make it clear text?
