10-24-2013 09:40 AM - edited 03-16-2019 08:03 PM
I setup extension mobility in Call manager but I am having a problem with the login. When i hit the services button i displays extension mobility but there is no place to enter the credintial information. I am running CUCM 8.6.1. I have ensured that extension mobility service is running on both publisher and subscriber, I have reset the Call manager service that is said i must when I activated the extension mobility in service paramaters. I have created the extension mobility phone service using http://<ipaddr>:8080/emapp/E<AppServlet?=#DEVICENAME#, xml service standard IP Phone Service and check enable. I built the device profile for hte phone. I have configured the user I have allowed control from CTI made my profile controlled. I have enabled device mobility selected the primary device. I have configured the phones to enable extension mobility and subscribed to extension mobility.
However there is no place to enter the login on the phone.
Solved! Go to Solution.
10-24-2013 10:24 AM
Reset the phone, if that does not work delete and add the service.
Chris
10-24-2013 10:14 AM
10-24-2013 10:23 AM
Thank you I updated the URL and updated the subscription, however i am still getting the same thing.
10-24-2013 10:24 AM
Chris
10-24-2013 10:32 AM
Thank you that worked.
