10-13-2008 10:25 AM - edited 03-15-2019 01:54 PM
I have a problem with Extention Mobility, the service Cisco Extension Mobility this configuted Maximum Login Time in 8:00 but the ip phones to make logoff after 5 minutes. The choice Enforce Maximum Login Time is true. Any solution?
Thank you
10-13-2008 10:57 AM
have you restarted the EM service after the change?
java
if this helps, please rate
10-13-2008 11:15 AM
I didnt change configuration, But how can restart Cisco Extension Mobility?
I'm using Call Manager 4.2
Thank you
10-13-2008 11:24 AM
I need to restart the service Cisco Tomcat?
Thank you
10-13-2008 01:18 PM
yes, on windows versions restart the tomcat service
java
10-13-2008 02:00 PM
i restarted this service but the problem persist
10-14-2008 01:03 PM
any suggestion?
