Community Member
Extension Mobility vs Logon Time
I have a problem with Extention Mobility, the service Cisco Extension Mobility this configuted Maximum Login Time in 8:00 but the ip phones to make logoff after 5 minutes. The choice Enforce Maximum Login Time is true. Any solution?
Thank you
Re: Extension Mobility vs Logon Time
have you restarted the EM service after the change?
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
I didnt change configuration, But how can restart Cisco Extension Mobility?
I'm using Call Manager 4.2
Thank you
Community Member
I need to restart the service Cisco Tomcat?
Thank you
yes, on windows versions restart the tomcat service
java
java
Community Member
i restarted this service but the problem persist
Community Member
any suggestion?
133
