Extension Mobility
i will like to understand the technology behind EM. when u create your userprofile, how will the CME associate that to my number configured under the ephone-dn because there is no place where d number to associate to the profile is specified.
i need to config EM for my client, i need to know how it will work. thanks
Hall of Fame Super Red
Re: Extension Mobility
Hi Sebastine,
The relationship for the DN (Directory Number) is built when you configure the User Profile. Take a look at Step 5. When the specified user logs into a phone using their Profile the IP Phone will populate the assigned number/numbers;
Configuring a User Profile
To configure a user profile for a phone user who logs into a Cisco Unified IP phone that is enabled for Extension Mobility, perform the following steps.
SUMMARY STEPS
1. enable
2. configure terminal
3. voice user-profile profile-tag
4. user name password password
5. number number type type
6. speed-dial speed-tag number [label label] [blf]
7. pin number
8. max-idle-time minutes
9. privacy-button
10. end
Here is a closer look at Step 5
Creates line definition.
•number-Directory number to be associated with and displayed next to a button on a phone that is configured with this profile.
number number[,...number] type type
Example:
Router(config-user-profile)# number 2001 type
silent-ring
Router(config-user-profile)# number 2002 type
beep-ring
Router(config-user-profile)# number 2003 type
feature-ring
Router(config-user-profile)# number 2004 type
monitor-ring
Router(config-user-profile)# number 2005,2006
type overlay
Router(config-user-profile)# number 2007,2008
type cw-overl
From this excellent doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html#wp1135822
Hope this helps!
Rob
Thanks for your response,so the cmd number 2001 type silent-ring means user with extension number 2001 can pick their call on logging in? Meaning i will be limited to just users on ap[articular phone since the a number per button if am using a phone with 8 buttons
Hi Sebastine,
For the first question, yes, the user with extension 2001 would have 2001 on Line Button 1 when logged in (in this example :) The example profile I sent was for a 6 button phone 796x but could also have been configured for an 8 button phone 797x. When the user logs in with their profile all lines will show on the phone.
Hope this helps!
Rob
118
