01-23-2009 07:52 PM - edited 03-15-2019 03:44 PM
Hi all,
I have a query about extension mobility. I am using CCM version 6.1.2.I want that the EM users should automatically logged out at 7 0'clock in the evening irrespective of any time they have logged in through EM.
Secondly, after 7 0' clock anybody wants to again login EM , he should be able to do so.
We have configured default time as 8 hours from the time they login.
regds,
aman
Solved! Go to Solution.
01-23-2009 08:34 PM
sorry, that capability is not implemented
there are no timers to control that, the only one is the forced logout after X time
java
if this helps, please rate
01-23-2009 08:34 PM
java
01-25-2009 08:56 PM
Thanks for info.
regds,
aman
02-06-2009 07:17 AM
Look at the product from www.rsconnect.net they might be able to do something for you
