extension mobility
SJ SJ
I have extension mobility in which the service parimeter is set for auto logout after 9 hours. I want 4 ip phones to be exempted from this rule i.e i want these phones to be logged out by the user not by auto logout. Is there any way to do that.
Jaime Valencia
The logout parameter is clusterwide, meaning it's all phones.
There is no way to configure a set of phones not to follow the rule.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
